Blind door safety
Dec 14, 2009 2 Replies
At work we have much used door between the floor and the offices. As it has no window, there are a lot of near collisions. Adding a window is not an option.
Does anyone know of a system with a pair of PIRs and simple warning lights? Something where a person approaching the door would cause a light on the other side of the door to go on. I know I could cobble together something easily enough, but a commercial solution would be more likely to be approved.
Thanks,
-Brian
Could you put a camera above the door on outswinging side and a LCD monitor above the door on the other side ?.
Doug
Probably could, but it seems a bit overkill. All I need is a light.
I know I've seen this product somewhere, but I can't think of what it would be called.
-Brian
