Zywall2 Problem! VPN Phase2 (No proposal chosen)
Mar 05, 2005 2 Replies
Help Me .....
Vpn Client is SSH Sentinel.
This is the problem
1 03/04/2005 23:47:34 Send:[HASH][DEL] 192.168.1.254 212.216.139.xxx
2 03/04/2005 23:47:34 Send:[HASH][NOTFY:NO_PROP_CHOSEN] 192.168.1.254
212.216.139.xxxIKE
3 03/04/2005 23:47:34 !! No proposal chosen 212.216.139.xxx192.168.1.254 IKE
4 03/04/2005 23:47:34 Start Phase 2: Quick Mode
5 03/04/2005 23:47:34 Recv:[HASH][SA][NONCE][ID][ID]
6 03/04/2005 23:47:33 Send:[HASH][ATTRIBUTE] 192.168.1.254
212.216.139.xxxIKE
7 03/04/2005 23:47:33 Phase 1 IKE SA process done 192.168.1.254
212.216.139.xxxIKE
8 03/04/2005 23:47:33 Send:[ID][HASH][NOTFY:INIT_CONTACT] 192.168.1.254
212.216.139.xxxIKE
9 03/04/2005 23:47:33 Recv:[ID][HASH][NOTFY:INIT_CONTACT]
10 03/04/2005 23:47:33 Send:[KE][NONCE] 192.168.1.254 212.216.139.xxxIKE
11 03/04/2005 23:47:32 Recv:[KE][NONCE] 212.216.139.xxx192.168.1.254 IKE
12 03/04/2005 23:47:31 Send:[SA][VID] 192.168.1.254 212.216.139.xxxIKE
13 03/04/2005 23:47:31 Recv:[SA][VID] 212.216.139.xxx192.168.1.254 IKE
14 03/04/2005 23:47:31 Recv Main Mode request from [212.216.139.183]
Thanks
See here for what this means:
The English in that article has been a bit butchered.,
In any case, it basically means that during phase 2 negotiation, 2 VPN parameters, 1 at each end of the tunnel, did not match. Double check that all your settings that are supposed to match on both endd do in fact match.
Shplad
