Watchguard Firebox III, OWA and 2 Exchange Servers
Jan 17, 2007 1 Replies
Hi All,
My Scenario:
- Firebox III 1000
- 2 Exchange Servers (SBS 2003 and 2000)
- 2 Public IP's NATed to Private IP's on the boxes
- Firebox service configured (years ago) and ports 80 and 443 are open
- Added new NAT to existing OWA rule and now allowing SBS traffic out through same rule
- 2 NIC's in the SBS2003 box (which is the one I have the issue with)
- Exchange 2000 OWA works fine (has for years)
- Can trace all the way to the public IP on the FB (for the SBS box)
- No traffic appears in FB logs for any port on the SBS server's IP (have enabled logging for both accepted and denied packets)
- Can access OWA internally on SBS2003 server
- ISA 2004 on SBS configured to allow all traffic through (temporarily)
What am I missing? I cannot get a response from the server. Also have had a couple of people look at the FB and SBS with no progress or suggestions at all.
Help greatly appreciated.
Merrick
PUBLIC IP1 X.X.X.1 PUBLIC IP2 X.X.X.2
Exchange 1: A.A.A.1 SBS Svr 1: A.A.A.2
You need to have two sets of rules, or one custom rule for each server:
HTTPS IN PUBLIC IP1 NAT to Exchange 1 IP PUBLIC IP2 NAT to SBS Svr IP
HTTP IN (you don't need HTTP for OWA, unless you really want to expose your servers in a bad way). PUBLIC IP1 NAT to Exchange 1 IP PUBLIC IP2 NAT to SBS Svr IP
Not sure how you have it setup for A/MX public records, but the above should get you OWA over HTTP/HTTPS to both servers.
Keep in mind, if you setup SBS Exchange properly, you need to do
(unless you redirect).
I have a BUNCH of WatchGuard appliances in the field and my home too, feel free to email me if needed (see sig for email address).
