WatchGuard Firebox III needs restart after flood
Jan 27, 2006 2 Replies
I have the Firebox III/700, WG version 6.2.B1292.
After a huge and rapid data transfer, it times out. By huge and rapid, I mean I am running a search crawler that crawls thousands of websites.
I found a similar issue with a similar product here:
Any help is highly appreciated.
Here is my log:
Log:
18051838 01/27/06 01:29:04 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18051868 01/27/06 01:29:10 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18051878 01/27/06 01:29:15 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18051908 01/27/06 01:29:20 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18051928 01/27/06 01:29:25 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18051958 01/27/06 01:29:35 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18051998 01/27/06 01:29:42 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18052028 01/27/06 01:29:49 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18052078 01/27/06 01:29:58 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18052088 01/27/06 01:30:04 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18052108 01/27/06 01:30:10 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
18052118 01/27/06 01:30:14 kernel eth0: Transmit timed out, status e4360000, CSR12 000050cc, resetting...
08 01/27/06 02:29:56 installd[52] Watchguard Installer Daemon 6.2.B1315 (C) 1996-2003 WGTI
18 01/27/06 02:29:56 installd[52] Performing loopback detect..
28 01/27/06 02:29:56 installd[52] Loopback: No loopbacks detected.
Hi
imho, the log does not contain sufficient information for a debug. Have you any opportunity to watch the incoming and outgoing packets ? "Transmit timed out" looks like too many connections to track.
Berk
snipped-for-privacy@gmail.com schrieb:
[snip]
You need to be running 7.x and the 4 service updates.
I never experienced the problems you are with 6.3, but the big question is why are you running such old firmware on the III/700?
