Suspicious Packets Using Yproxy
Aug 04, 2004 3 Replies
Jump to replies (3)
Like many others, I use Yproxy to decode yenc files. I also run Agnitum Firewall Pro.
Strangely, -after- I disconnect from Yproxy, the firewall reports "suspicious packets" from Yproxy, presumably running a port scan.
Is this normal, or should I be alarmed?
Thanks,
Chas.
I get reports of "suspicious packets" from the Yproxy site itself, just as I disconnect from it. The packets are sent to a different port each time.
Chas.
Can you provide more information, like what specific activity is reported? In particular, what protocol and what are the source and destination ports and addresses?
You already said that. I don't think you know what you're talking about.
