Routing 2 different streams from the same IP address
Sep 29, 2005 3 Replies
Jump to replies (3)
Hi All,
Forgive my ignorance, but I am not really the network admin I'm just trying to get information to understand our problem better.
We have a box that runs 2 different applications that both send interfaced data. We are in a situation now that requires us to route the 2 streams over the the same firewall (Cisco PIX) to 2 different IP addresses and ports. The issue we are having is that the streams come from the same IP and we can't use port translation as each time the application opens a conenction it grabs any available port (we are unable to set a static port to send from on the applications). So we haven't figured out how to seperate the streams since we can't define the port they are originating from.
Basically IP n.n.n.140 sends 2 streams of data over 2 different ports that are dynamically chosen from the normal range. Stream A needs to go to destination n.n.n.8 port 850, and stream B needs to go to destination n.n.n.14 port 6343.
Any ideas to set us on the correct path would be appreciated.
Thanks, Cory
I don't think PIX's do Policy Based Routing. I could be wrong - but its not that common on firewalls.
What exactly do you want to filter out? What layer 5/6 protocol is used? Is the PIX capable of that protocol?
Yours, VB.
