Router NetGear Pack DG834PN ?
Mar 22, 2008 0 Replies
Hello,
I Have a question about router configuration ,
I wanted to set up a ventrilo server (Voip) , I had to enter the port (3784) TCP and UDP.
In the menu it was proposed TCP / UDP, TCP or UDP
I had to create two rules for the port 3784, a TCP and another for UDP, In this way the server is running..
I tried creating a single rules for the port 3784, By choose TCP/UDP for this port, with this configuration the serveur doesn't work. I doesn' t understand why ??
I thought that the option TCP / UDP allowing the UDP and TCP At the same time.
But here does not seem to be as !
What mean exactly the option TCP/UDP ?
Many thank in advance
Jean
