This network worm spreads via local networks and removable storage media. The program itself is a Windows PE DLL file. The worm components vary in size from 155KB to 165KB. It is packed using UPX. Heres how to remove kido.ih and kido.fx and kido conficker.dv
Remove Net worm win32 kido.ih, kido conficker.dv and kido.fx
Apr 24, 2009
Most relevant reply
@ANSGAR, IT DOSE , heres how to remove win32 kido.ih, conficker.dv worm manually
Removal tools are no solution to an infection, particularly not with malware that may download more malware or may give an attacker remote access. One can never be sure what else was modified on the system and thus can never be certain that the malware was removed entirely.
cu
59cobaltAnsgar -59cobalt- Wiechers wrote in news: snipped-for-privacy@news.in-ulm.de:
Not to mention, why should I trust a "removal tool" advertised by a no-name in a usenet group?
But, I guess there's enough stupid people in the world it's worth their effort.
Brian
@ SkyWize Not all removal tools reallyw ork but there are sevrel removal tools that work and also the site i mentioned ,has manual removal guide Thx
That doesn't change anything at all about the problems outlined in .
It also doesn't change anything at all about the fact that all of your postings are off-topic in this group, as they don't have anything to do with firewalls.
cu
59cobaltit dose man
Get lost, dimwit.
cu
59cobaltOoops! @ ANSGaR it really dose man, why dont you believe, try it yourself, ;)
Look, dimwit, I'll make this simple for you:
- You're wrong.
- You're off-topic.
- Get lost.
Was that easy enough for you to understand?
cu
59cobalt@ANSGAR, IT DOSE , heres how to remove win32 kido.ih, conficker.dv worm manually
Nope.
cu
59cobalt@ ANSGR There no treatment of fools
Isn't that true ...
cu
59cobalt@ANSGR: Yes, thats True, i tried too much to treat you, but useless hehehhehe
i can do that
