Zonealarm askes if I want to allow ptzsh.exe to access the internet. I can't find any reference to ptzsh.exe on the net. IOn my hard drive i is in the System folder on this Windows Me machine. Does anyone know what this program refers to?
ptzsh.exe
Aug 11, 2004
Could you do a search for this file on your system?
PS: I wouldn't allow this program to do anything untill you know what it is. Otherwise ZA would be a useless tool on your system.
I did the serarch and it sits in the Windows System folder. I'm not going to click on the .exe file, and I won't allow it to access the internet. But I don't want to delete it either, unless I know what it is.
What other newsgroups would it be a good idea to post this question to?
Thanks.
Try selection the file/rightmouse click/properties and see what info this gives you.
As a temp workaround you can rename the file from ptzsh.exe to ptzsh.exe_suspicious so i cannot ever be executed anymore.
