Pass-lock in ZonaAlarm Free
Mar 24, 2006 2 Replies
Using ZonaAlarm Free v6.1.744 on Windows XP MCE, I want to enable ?passlock? for a particular program.
The program is in the list at: Program Control >> Programs It can be selected. The ?Help? file says to ?click Options? but I don?t see any button or menu command for ?Options?. Must be overlooking it someplace. Could somebody point out where to look for ?Options??
The program list has columns for ?Access? and ?Server? but not for ?Pass Lock? or ?Send Mail?.
Thanks.
Could you please write that s*it correctly in future? You're bypassing my bullshit filter.
You should disable it for all programs, except you won't to shoot yourself in the foot even more that you're already doing by running this piece of bit-junk.
These are meaningless anyway.
In the program list, 'right' click on the program name. If that 'options' option is grayed out in the menu that comes up it may not be available in the free version. HTH
