Nokia IP260 R60
Apr 23, 2007 2 Replies
Hello,
I have problem with my firewall, after i hange the admin password (about week later) my firewall block any packets, and i don't have internet and all connectivity - something like drop any any rule.
Do you have similiar problem ?
Thanks
best regards
Thomas.
I have similar problem with my firewall nokia IP 260. One day firewall started blocking all incoming connections on all network interfaces. After log into the firewall via serial cable I can ping and connect computers from intranet as well as from internet. So it looks like router switched into autistic mode where only outcoming connections from the router can be made.
Still don't have a solution for this issue.
Does antibody can help?
anybody not antibody of course :)
Thanks, Marek Wasilewski
