Need Opinion on the Following Suspicious Activity
Aug 17, 2006 4 Replies
Jump to replies (4)
Need Opinion on the Following Suspicious Activity open original image
I noticed that even when I have nothing open in Windows XP Pro SP2, there is activity galore...see below. I am not too sure how to address this. Spyware software didn't catch anything out of the ordinary and ZoneAlarm Firewall did not catch anything sinister either. There is always net activity being received onto my computer even when it is not being used and nothing is running. Please advise if at all possible as to what this is: Thanks very much.
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
C:\\Documents and Settings\\user>netstat
Active Connections
Proto Local Address Foreign Address State TCP xppro:1046 64.215.164.234:http ESTABLISHED TCP xppro:1047 207.46.20.93:http ESTABLISHED TCP xppro:1048 64.4.21.189:https ESTABLISHED TCP xppro:2869 192.168.0.1:6063 TIME_WAIT TCP xppro:2869 192.168.0.1:6064 TIME_WAIT TCP xppro:2869 192.168.0.1:6065 TIME_WAIT
Start by looking up the IP addresses and see if they have anything to do with your connection:
| I noticed that even when I have nothing open in Windows XP Pro SP2, there is | activity galore...see below. I am not too sure how to address this. | Spyware software didn't catch anything out of the ordinary and ZoneAlarm | Firewall did not catch anything sinister either. There is always net | activity being received onto my computer even when it is not being used and | nothing is running. Please advise if at all possible as to what this is: | Thanks very much. | | Microsoft Windows XP [Version 5.1.2600] | (C) Copyright 1985-2001 Microsoft Corp. | | C:\\Documents and Settings\\user>netstat | | Active Connections | | Proto Local Address Foreign Address State | TCP xppro:1046 64.215.164.234:http ESTABLISHED | TCP xppro:1047 207.46.20.93:http ESTABLISHED | TCP xppro:1048 64.4.21.189:https ESTABLISHED | TCP xppro:2869 192.168.0.1:6063 TIME_WAIT | TCP xppro:2869 192.168.0.1:6064 TIME_WAIT | TCP xppro:2869 192.168.0.1:6065 TIME_WAIT |
What's so suspicious ?
HotMail ? Microsoft ?
The http connections are the Windows Update site. Maybe you have automatic updates turned on? (good)
The other lines appear to be UPnP traffic from your computer to your local router. Nothing suspicious. You can disable Universal Plug and Play on the router and/or turn off the services that support it on your PC if you don't like it. (Start-> Run-> SERVICES.MSC and set SSDP Discovery Service and Universal Plug and Play Device Host to disabled and stopped ) MSN/Windows Live Messenger, if you use it, is also known to generate some UPnP traffic on its own regardless of whether you turn the services off.
About UPnP:
Colin, thanks very much for your explanation to this. Much appreciated.
Jeff
