May be a Firewall Problem!
May 23, 2006 1 Replies
Duane Arnold
What happens when you drop the PFW(s) on the machines and try to network, since I'll assume they are being a NAT router? If they don't network after the PFW(s) have been dropped, then what's the PFW have to do with it is the question? Duane :)
I have just upgraded my Trend Micro software. It has always done its job. No problems.
The Brand new installation seems to work well except....
I have installed a home wireless network. The two computer that are connected work well independantly but will not talk to each other.
I have checked every setting. In this program you have a dialogue box that you can say whether a connection, in this case my other machine, is trusted or not and so you can permit or deny access.
I mark this as trusted but it tells me the machine is 'offline'. No it isn't.
How do I put that right , any suggestion. I have played ring around rosie with the help desk, but cannot connect with it it keeps takingme back to a home page instead of connecting me to the help desk or knowledgebase.
Duane :)
