Management unable to communicate with firewall cluster
Aug 20, 2005 0 Replies
Hi all,
I got a serious problem in my firewall cluster which are running Check Point NG AI R55 with Rainfinity RainWall 3.1 SP5 R1. Here are the scenario:
Both firewalls are in cluster (HA and load balancing mode). When I took the secondary firewall offline for maintenance, suddenly the management is losing contact with the primary firewall. I'm unable to push the policies towards the primary firewall. The secondary firewall... I did a installation from scratch for Check Point and rainfinity unfortunately, the firewall management servers unable to recognize the secondary firewall!
Where I did wrong? How to fix this problem?
Thanks.
Regards,
Alex
