Dear experts,
I had a problem with our firewall cluster which doesn't work properly due to the synchronization error as stated below:
*fwe3 firewall* Apr 13 11:05:40 fwe3xxx.xxxx.xx fw: [ID 544343 kern.notice] CPHA: Found another machine with same cluster ID. There is probably another cluster Apr 13 11:05:40 fwe3xxx.xxxx.xx connected to the same switch/hub as this one. Apr 13 11:05:40 fwe3xxx.xxxx.xx fw: [ID 407823 kern.notice] CPHA: This is an illegal configuration. Each cluster should be connected to another set of switches/hubs.
The firewall's H.A link detected that its partner is down.
Cluster Mode: Sync only (OPSEC)
Number Unique Address Firewall State (*)
1 10.1.0.1 down
2 (local) 10.1.0.3 active
(*) FW-1 monitors only the sync operation and the security policy Use OPSEC's monitoring tool to get the cluster status
and it is similar to fwe1 firewall as shown below.
*fwe1 firewall
*Apr 13 11:05:30 fwe1xxx.xxxx.xx fw: CPHA: Found another machine with same cluster ID. There is probably another cluster Apr 13 11:05:30 fwe1xxx.xxxx.xx connected to the same switch/hub as this one. Apr 13 11:05:30 fwe1xxx.xxxx.xx fw: CPHA: This is an illegal configuration. Each cluster should be connected to another set of switches/hubs.
1(local) 10.1.0.1 active
2 10.1.0.3 down
How to fix this? FYI, I'm using RainWall 3.1 SP5 and Check Point NG AI R55 HFA15. Please help me on this matter.
Thanks very much.
Regards,
Al
