Hi all, Just want to know, is it possible to manage a remote enforcement module from SmartCenter with different IP? Let say our company had three enforcement module and two SmartCenter server which located on two different location. One location has a SmartCenter server and two enforcement modules (in cluster mode), while the other location has one SmartCenter server and an enforcement module. These two location resided in two different network (using public IPs). Both management servers (SmartCenter) managed/connected to each enforcement servers in private network. Below are the details: Location A
---------------- SmartCenter server : 192.168.1.26 (int) 130.188.5.20 (NAT) Enforcement module A : 192.168.1.5 (int) 130.188.5.6 (ext) Enforcement module B : 192.168.1.6 (int) 130 188.5.7 (ext) Enforcement Cluster IP (VIP) : 130.188.5.4 Note : This is a firewall cluster which use RainWall as a HA or Load-balancing mode. Location B
--------------- SmartCenter server : 192.168.1.26 (int) 130.188.9.13 (NAT) Enforcement module : 192.168.1.5 (int) 130.188.9.12 (ext) I would like to use the SmartCenter server (Location A) to manage enforcement module (location B). Is it possible? How do I set or configure SmartCenter server (Location A) to manage remote enforcement module? What kind of configuration that I should take note? Any gotchas that I should expect ? Thanks for your help. Regards, Alex Simbun
