Kerio vs. Zone Alarm - UDP Ports
Jul 04, 2006 1 Replies
Hello,
I recently needed to make ZoneAlarm (Free Edition) allow an incoming UDP Port, but it appeared that Zone Alarm Free Edition is unable to do this.
So I downloaded Kerio, and installed it. I did not make any adjustments to Kerio, and the application which needed data from the UDP port just started working.
My question: If ZoneAlarm by default blocks incoming UDP requests, and Kerio does not, then what security am I losing by using Kerio vs. ZoneAlarm?
Thanks
--Took
It's broken by design then.
Exactly the difference between the two statements above.
Maybe it would be a good idea to drop both of them and use the Windows-Firewall, or you could read this:
Yours, VB.
