Check out m0n0wall...
Hi Gre, Greg Hennessy wrote in Well - we tried to try out m0n0wall. no luck - because at the console- login where no key-inputs possible - keybord was dead. - and that machine runs an ip-cop test-setup very well.... we will have a look at pfsense - i haven't had heard of itβ¦
I' looking for something like IPCop ( which has a realy beautyful web-gui ) which is "more a generic router"
I''d like to have also web-adminable routing between all available interfaces not to be limited to some Colors.
It should be free and based on iptables.
( I intentionally avoid smoothwall )
any suggestions ?
kind regards,
Stefan
Why are you ruling out monowall or pfsense ?
greg
Hi Gre,
Greg Hennessy wrote in news: snipped-for-privacy@4ax.com:
we will have a look at pfsense - i haven't had heard of it before.
at the moment I'm using OpenBSD for firewalling, but my collegues are somewhat swamped with doing things the command-line-way.
I'm not shure about ipfw opposit to pf and iptables - on a first glance iptables looks most flexible while pf seems most robust ...
I already thought about An OpenBSD-Box with webmin - but In this case the Setup could possibly run into trouble caused by to less experiences ...
hard to decide what to take...
More Ideas / thoughts are welcome.
Kind regards
Stefan
You don't need to input anything into the console. Just connect up a PC to each of the NICs until you can get an IP via DHCP. Once you do, hit the web interface and you're good to go.
