New kind o' network job landed in my hands; I'm helping a client put an IP camera in each of his stores;
3 don't work & 3 do (1 just needed to reset the camera & port after a power failure).
The remaining stores have ATT/ma bell's netopia routers (setting into bridge mode), which drop over to linksys routers; non-wireless 4 ports w/ a wan i/o. The prior tech hadn't requested a block of static IP's, which I just did Friday, after a LONG run-around to confirm that I was an authorized person to modify the account.... _____________ This is where I need help; Now I need to poke a hole thru the linksys, to allow the camera(s) to send out to the net, using a new static IP.
Any hints, warnings, or provisos would be greatly appreciated! Thanks kindly! Amanda
