Intrusion Attack
Apr 12, 2006 22 Replies
Hi Don, Thanks for answering me so many times. Yes Our Network uses DHCP . In NetBIOS settings DHCP(Default option) is checked so , Should I choose Disable NetBIOS over TCP/IP . And while doing so what effects/changes can be seen.
With Regards James
Yes. You can disable NetBIOS over TCP/IP option, but whether you choose to disable NetBIOS over TCP/IP or leave it enabled, other systems will not be able to access your system because of your use of a personal firewall. More important disabling or leaving it enabled will not stop other systems from attempting to connect to your system. They'll still attempt it and your use of a personal firewall will still display a warning dialog.
After cooking, at least at McBurgerKong.
