Flood of alert messages
Sep 22, 2006 3 Replies
Jump to replies (3)
Since this morning my Netgear firewall has been sending me many alert mails, each with a long list of detailed alerts like the following (made anonymous) sample:
Fri, 2006-09-22 11:52:30 - UDP packet - Source:221.12.26.aa,25353,WAN - Destination:84.158.xx.yy,22030,LAN [Drop] - [Inbound Default rule match]
Fri, 2006-09-22 11:52:30 - UDP packet - Source:83.116.32.bb,52706,WAN - Destination:84.158.xx.yy,22030,LAN [Drop] - [Inbound Default rule match]
Fri, 2006-09-22 11:52:33 - UDP packet - Source:217.165.30.cc,60777,WAN - Destination:84.158.xx.yy,22030,LAN [Drop] - [Inbound Default rule match]
Fri, 2006-09-22 11:52:36 - UDP packet - Source:71.133.167.dd,22221,WAN - Destination:84.158.xx.yy,22030,LAN [Drop] - [Inbound Default rule match]
(the IP address of my router is 84.158.xx.yy)
What may be the cause of these messages? Is there anything which I should be worried about on my side?
Torsten Villnow
A vast majority of MS machines used by dumbass users have been infected recently and they are trying to reach out to other machines.
Your machines are behind a router and the unsolicited inbound traffic is being dropped.
So why are you worried about dropped traffic? You shouldn't be and you should go on about your business of using the computers behind the router and forget about it.
Duane :)
My question was, whether I should be worried. Your answer stopped me thinking about whether I should be worried ... :-)
Thanks!
Torsten Villnow
Torsten Villnow schrieb:
Actually you should be worried. Because you obviously do not understand what is going on in your network and/or systems.
I am not trying to be rude here, but understanding the logs (and the basics of IP) would be very helpful.
Regards Thomas
