Easy port question
Jun 29, 2005 8 Replies
Jump to replies (8)
If you have more than one system, use nmap to check another box.
do a port scan from another system. I have not check any of these for over 2 years. They are not in any order to speak of.
! port scan (bottom of pg)
! security port scan
! security port scan of you system
! trojan port scanner
! security port scan of system
! security scan check
Nope, it couldn't find the correct IP address. Thanks, anyway.
Yup, that's what I'm saying. BTW, I was told today I dont need to check ports - a wireless firewall only allows 1 port in and 4 ports out. My device instructions say it needs specific ports open. Both can't be true, right?
Thanks. I'll try it tomorrow.
Are you saying that using the links at that site that lead toward the Advanced Port Scanner couldn't determine your IP? The advanced port scanner would be able to let you select one specific port to test and how you wanted to test it, with TCP connect or TCP syn type.
That doesn't sound right. What about
or similar.
A website has to see the IP you look like or it can't send you its webpage.
What are you talking about here?
What's a wireless firewall?
Just what device is it brand name and model?
Duane :)
The IP address for
195.131.4.164 Casey
My fault, I meant s/w firewall - Norton. device = Tivo.
