My company is in the process of repartitioning the network, including the adoption of a DMZ for all of our web based servers and wireless clients. All DMZ computers will use private IP addresses with NAT for any public access required. My question is this: For the wireless clients in the DMZ I need to have DHCP available. Should I allow this traffic through the router / firewall's internal interfaces and try to use my existing DHCP server? Or should I install DHCP on one of the DMZ computers? I'm leaning towards allowing DHCP using my existing server if possible. If I can do this what do I need to do to specify the use of a second DHCP zone? My DHCP server is running Windows 2003 with the standard Microsoft DHCP server.
DMZ & DHCP
Sep 26, 2005
Most relevant reply
I want to put all the WAPs into the DMZ so that anyone who wants access to resources on the internal network has to VPN in over the wireless. To do that with our existing infrastructure I need DHCP. I'll just pick one of the servers I'm migrating into the DMZ and install…
Read the full replyI want to put all the WAPs into the DMZ so that anyone who wants access to resources on the internal network has to VPN in over the wireless. To do that with our existing infrastructure I need DHCP. I'll just pick one of the servers I'm migrating into the DMZ and install another copy of Microsoft's DHCP client there. Definitely the most straightforward solution.
I think I would use a separate dhcp server in the dmz -- setting up a dhcp server to dish out ip's in a range that it's not even participating in would be ugly. Why allow such traffic across the dmz boundary?
And btw why do you need DHCP in your DMZ? Aren't the servers using static IP's? If not, how do you reach them from the other zones?
-Russ.
