Client VPN Cisco HELP
May 20, 2006 1 Replies
Most relevant reply
tippenring
If I'm reading your question right, there may be two easy options. Add the 192.16.1.x to your IGP. Change your pool to a subnet of the local IP range, such as 170.20.1.1-170.20.1.15.
Hello, I have a PIX 515E, and I use client VPN CISCO 4.6 for connection VPN. I use VPN pool 192.16.1.0/25 and my network inside is 170.20.1.251/23. It's all right.
But I have a problem: The 192.16.1.x transit in my network !!! Could I translate the remote IP address 192.16.1.x in intern address
170.20.X.X? I try the command static (inside,outside) 192.16.1.0 170.20.1.160 netmask 255.255.255.224 but I received the message Addresses overlap with existing localpool range
What is the solution ? Could I translate my remote pool VPN with my PIX or I have to add a cisco element between my PIX (firewall, VPN) and intern network ? Thank you for your help, Silviu
