Blocking Warez P2P
Jan 16, 2005 2 Replies
I'm looking for the port ranges for the WAREZ P2P client so I can disable them up/down.
Thanks David
Most helpful,
thank you
drop TCP 6345 6349
BUT.... this won't solve your problem. It does however help you in the sense that whoever is P2P'ing after that is clearly breaking your `zero tolerance` traffic rule. (You need to have one)
Why ?
Todays P2P clients will do anything to reach the net, it will even leave the network over port 80 if it can't make a connection to the internet, how rude :)
While i know the benifit of proxy's, i refuse to implant one just to stop P2P traffic. (Unless you have a $$$ layer 7 appliance firewall with an IDS module in it) I suggest you inform (crack some skulls) the people on your lan not to use P2P on the LAN if they know whats good for them :)
(You can spot P2P pretty well with snort
