Linksys Routers
Apr 04, 2005 6 Replies
Jump to replies (6)
We're wondering whether other people are seeing this problem:
We have, over the last year, installed numerous Linksys routers -- the newer firmware bearing the Cisco brand -- all of which are crashing the networks they're on. These are the 4 port Cable/DSL router.
It is definitely the router doing it -- we've replaced some with DLinks and the problems immediately stopped.
Internet access is unaffected; it just causes intermittent disconnects of workstations for no apparent reason. In one instance, we had an exceptionally stable network with the earlier model Linksys router. The router failed and was replaced with the new model, and the problems began. Ten days later we put in a DLink and all is well.
The Linksys tech support people have recommended the flash upgrades, but we have yet to get the upgrade to work on one of them, and they deny the problem anyway.
Wondering if anyone else is seeing this. Anyone want to buy some new Linksys routers pulled from service?
IF tech support is not being helpful, then escalate the problem. IF they fail to escalate it and solve the problem, start writing letters to the president of linsys and the CEO of Cisco. Become the squeaky wheel that needs to be greased.
--Dale
Please forgive me if this seems a stupid question, but did you turn off DCHP on all of them and make sure it stayed off?
In article , Dale Farmer wrote: :IF tech support is not being helpful, then escalate the problem. IF they :fail to escalate it and solve the problem, start writing letters to the :president :of linsys and the CEO of Cisco. Become the squeaky wheel that needs :to be greased.
I'm not the OP, but I'll interject for a moment:
Sometimes it's just not worth chasing down a problem.
Being the "squeaky wheel" requires writing email, making calls, playing phone tag, being pushy, explaining the incident to your supervisor, explaining to your supervisor what the response is so far, explaining to your supervisor's supervisor why the problem still hasn't been solved...
What's the ROI? If your network is broken and people can't work, then you are losing money, and the longer you go without a solution, the more money you lose and the faster you lose it. Meanwhile your salary has to be paid for the time you are squeaking, your supervisor has to be paid to "manage" your squeaking, the people who can't work have to have their salary paid.
Suppose that you called today (Monday) and managed to get through to Someone With Authority, and they said, "Yessir, we'll fly in the Product Manager and the engineering lead for that product, and they will work on the problem all day and all night until the problem is tracked down; and if necessary, we'll issue ECO's and have our factories modify the hardware. We can have them there from a different continent on Thursday afternoon." Could your organization last the rest of the week with a broken network?
Our branch isn't particularily big, but we estimate that after the first few hours [when people can get caught up reading journals or attending meetings or cleaning their rooms] -- that once the slop time is used up, that it costs us about $C10,000 per hour in salaries. If we were a "business" it could cost us far far more than that in lost sales. To low-ball it, call it $US50,000 per day lost... lost primarily due to the stubborn will to be the "squeaky wheel" instead of just cutting losses and going with a different product or configuration that is known to work.
snipped-for-privacy@gmail.com schrieb:
Dont't know what you mean with "network crash" - we're using BEFSX41 and had really big problems with the official firmware release. (Router rebootet when it gets udp packets etc...) Pls describe your problem a little more detailed, and tell me which firmware you're using...
regards,
joerg
yeah -- these things are $50 apiece and we're just swapping them out. I've probably put in 100 or more Linksys routers over the years with never a problem. Anyway, we've just started replacing them with Dlinks.
Someone asked about the DHCP server, but we don't want it disabled because we use them in lieu of the Windows DHCP server as these are all small (
