VPN Errors on multilink T1 - but inly for DHCP and not static NAT users?
Apr 04, 2008 1 Replies
Tilman Schmidt
It's not too clear what you or your users are trying to do, but as a wild guess, you may have hit the fact that standard IPSec does not work across NAT. If so, you'll want to use the "NAT traversal" option. HTH T.
I have a Cisco 1700 router with dual WIC/T1's
LAN users are assigned NAT IP addresses from the Cisco 1700 via DHCP from 10.0.0.100 to 10.0.0.200.
10.0.0.2 - 10.0.0.15 are 1:1 configured to our 16 internet routable IP addresses.
Users who receive an IP address via DHCP have all desired functionality, including surfing, email, etc... however they cannot establish a VPN.
The same users can statically assign a 1:1 IP address (i.e. 10.0.0.15) and establish a VPN without any issue.
Im stuck. Anyone know why this is happening?
HTH T.
