Using certificate authentication on VPN tunnel instaed of preshared
May 15, 2005 3 Replies
Jump to replies (3)
Hi!
I have problem with using certificates to authenticate VPN connection between PIX and Cisco VPN client.
First, I have configure VPN tunnel authenticated with preshared keys and everything was working just fine! Then I have configured certificate use.
( with commands: ca identity jowisz x.x.x.x:/certsrv/mscep/mscep.dll ca configure jowisz ra 1 20 crloptional ca auth jowisz ca enroll serial_number)
Finaly I have changed isakmp policy from:
isakmp policy 40 authentication pre-share isakmp policy 40 encryption aes-256 isakmp policy 40 hash sha isakmp policy 40 group 5 isakmp policy 40 lifetime 86400
to:
no isakmp policy 40 isakmp policy 40 authentication rsa-sig isakmp policy 40 encryption aes-256 isakmp policy 40 hash sha isakmp policy 40 group 5 isakmp policy 40 lifetime 86400
and then connection was always terminated by VPN client with code 401 (an unknown reason). After investigating isakmp conversation I have fount than PIX can not assign IP address to VPN client (I have no idea why, as I have configured appropriate pool and have assigned it to vpngroup) . Then I have discovered, that issuing a command:
# isakmp client configuration address-pool local my_pool_name
makes things a little better. Now I can establish working VPN tunnel, but:
  1. tunnel spit did not work - it was working on preshared authentication
  2. VPN client receives an IP address via DHCP, but didn't receive an DNS server IP address and domain name (defined via vpngroup).
My PIX is 515E with version 6.3
Quick network description:
10.1.0.0/16 ----- pix ----internet ---- VPN clinet with IP 10.1.111.0/24 | ------ other network (192.168.0.0/24)
and here is my abbreviated config:
PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 auto ... nameif ethernet0 outside security0 nameif ethernet1 inside security100 ... enable password xxxxxxxxxxxxxx encrypted passwd xxxxxxxxxxxxxxxxx encrypted hostname pix domain-name mydomain.com .... access-list inside_outbound_nat0_acl permit ip any 10.1.110.0 255.255.255.0 access-list inside_outbound_nat0_acl permit ip 10.1.0.0 255.255.0.0
10.1.111.0 255.255.255.0 ... access-list outside_cryptomap_dyn_20 permit ip any 10.1.110.0 255.255.255.0 access-list pd_split_cert_splitTunnelAcl permit ip 10.1.0.0 255.255.0.0 any access-list pd_split_cert_splitTunnelAcl permit ip 192.168.0.0 255.255.0.0 any access-list outside_cryptomap_dyn_40 permit ip any 10.1.111.0 255.255.255.0 ..... ip address outside a.b.c.d 255.255.255.128 ip address inside 10.1.0.1 255.255.0.0 ...... ip verify reverse-path interface outside ip verify reverse-path interface inside ..... ip local pool my_pool_1 10.1.110.1-10.1.110.254 ip local pool my_pool_2 10.1.111.1-10.1.111.254 .... nat (inside) 0 access-list inside_outbound_nat0_acl ..... route outside 0.0.0.0 0.0.0.0 a.b.c.1 1 ..... aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server TACACS+ (inside) host x.y.z.w xxxxxxxxxxx timeout 5 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local .... floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20 crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5 crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40 crypto dynamic-map outside_dyn_map 40 set transform-set ESP-AES-256-SHA crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map client authentication TACACS+ LOCAL crypto map outside_map interface outside isakmp enable outside isakmp policy 20 authentication pre-share isakmp policy 20 encryption aes-256 isakmp policy 20 hash sha isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 isakmp policy 40 authentication rsa-sig isakmp policy 40 encryption aes-256 isakmp policy 40 hash sha isakmp policy 40 group 5 isakmp policy 40 lifetime 86400 vpngroup my_vpn_group_1 address-pool my_pool_1 vpngroup my_vpn_group_1 dns-server 10.1.1.16 10.1.1.15 vpngroup my_vpn_group_1 wins-server 10.1.1.16 10.1.1.15 vpngroup my_vpn_group_1 default-domain mydomain.com vpngroup my_vpn_group_1 pfs vpngroup my_vpn_group_1 idle-time 1800 vpngroup my_vpn_group_1 password ******** vpngroup my_vpn_group_2 address-pool my_pool_2 vpngroup my_vpn_group_2 dns-server 10.1.1.16 10.1.1.15 vpngroup my_vpn_group_2 default-domain mydomain.com vpngroup my_vpn_group_2 split-tunnel pd_split_cert_splitTunnelAcl vpngroup my_vpn_group_2 idle-time 1800 vpngroup my_vpn_group_2 password ******** ca identity jowisz 10.1.0.10:/certsrv/mscep/mscep.dll ca configure jowisz ra 1 20 crloptional ..... management-access inside .... username yyyyyyyyyyyyy password xxxxxxxxxxxxxxxx encrypted privilege 15
Can anyone help me to solve this? (Or at last explain what is going on?)
Best regards: Krzysztof
The ou in your cert matches the vpngroup my_vpn_group_1?
//TC
"Krzysztof" skrev i meddelandet news:d6868b$ksk$ snipped-for-privacy@news.onet.pl...
Hi!
No! Probably this is the case! (unfortunatly I can't check this until next week)
But thank you for your note.
Best regards:
Krzysztof
