VPN consentrator connection over TCP port 10000
May 19, 2005 4 Replies
Jump to replies (4)
VPN consentrator connection over TCP port 10000 open original image
How would I setup VPN consentrator to suppot Cisco VPN client connection over TCP port 10000? All I would like to prove a concept. If anyone would be nice to list the commands it would be really apprecated. Thank you Al
In article , Al wrote: :How would I setup VPN consentrator to suppot Cisco VPN client :connection over TCP port 10000? All I would like to prove a concept. If :anyone would be nice to list the commands it would be really :apprecated.
I doubt you can do that at all. For backwards compatability, the client can talk on *UDP* 10000.
These days, though, why not just use standard NAT-T on UDP 4500 ?
I have a problem with connecting multiple Cisco VPN clients that are behind a firewall to a VPn concentrator. At the moment only 1 person can connect. Thank You
In article , Al wrote: :I have a problem with connecting multiple Cisco VPN clients that are :behind a firewall to a VPn concentrator. At the moment only 1 person :can connect.
That's a standard problem. Turn on NAT Traversal (the link shows how), and make sure that UDP 500 and UDP 4500 are open.
Without NAT-Traversal being on, ESP (IP Protocol 50) is used, and since ESP has no 'port', very few firewalls are able to NAT more than one internal ESP source to a shared IP address. NAT-T encapsulates ESP within UDP and so works fine with PAT (Port Address Translation.)
