Voip question
Feb 15, 2007 2 Replies
Voip question open original image
Hi, We are checking different solutions for VOIP. It seems Cisco is one of the most expensive ones. I checked different documents and options to justify this difference in cost but couldnt come up with strong reasons. Can someone tel me why I should pick Cisco VOIP solution? and if there is any comparison available between Cisco and for example Mitel? Thanks for any help.Rob
Hi Rob,
You may wish to investigate the Cisco Solution Designer:
As well as Cisco vs. Competitor Lab Tests:
Sincerely,
Brad Reese
Hi Rob, Full disclosure, I work for Mitel and wanted to respond to your call for assistance. The following is a link to a 2005 Miercom report that includes, amongst other things, a cost analysis done on the Mitel 3300 ICP and the Cisco system. Mitel will be introducing its latest release (Rel. 8) of the 3300 at VoiceCon in March. Copy the below into your browser.
Sincerely, Paul Goyette paul snipped-for-privacy@mitel.com
