VOIP problem in Cisco 1751V
Mar 03, 2006 1 Replies
VOIP problem in Cisco 1751V open original image
Hi friends,
I just wanted to let you know that I am seeing a bizarre problem in Cisco 1751V with IOS 12.3(10). The two routers are connected via leased line and both are equipped with a VIC-2FXS card.
However, suddenly voice calls from Location 1 to Location 2 stop working. You may want to read my previous post on the same issue mentioned in the below URL:
I was advised to enable buffer logging at debugging level. When I opened the log using show log, I saw multiple lines with the following entry:
ASSERTION FAILED: file "../src-m860-les/ipm_dsprm.c".
I have seen in some site that this is due to some IOS Bug. But I am not able to browse the Cisco Bug Navigator as I dont have a CCO account.
Everything works fine after a router restart. I have still not tried manually shutting / unshutting the voice ports and seeing if it works.
Does anybody have any ideas on this? Requesting for your earnest help in this regard.
Thanks a lot Gautam
Guatam,
You don't need a CCO account to search error messages in a log.. ex:
not looking at your previous thread or seeing your configs and assuming you changed nothing and it was working correctly..it sounds like a bug. Given that try changing the code around.
/mike Michael Wiley, CCIE 13271
