Upgrading code on 3760... in stack mode.
May 25, 2005 1 Replies
Hey Guys,
I have a 3 member stack, which I'd like to upgrade code to each of the switches in the near future.
What is the correct way to approach this ?
Details on the following would be great:
  1. TFTP-ing code is simple. How would I point the a slave to use newly uploaded code ? (i.e. in a similair manner as using the boot system flash:xxxx.bin command)
Thoughts ?
In article , fonzii wrote: :I have a 3 member stack, which I'd like to upgrade code to each of the :switches in the near future.
:What is the correct way to approach this ?
Update to the master. The master will update the others [if I recall correctly.] The master ensures that all the versions are in sync.
Note: when I reviewed the relevant documents a number of months ago, if the master was EMI, it would update any SMI clients to EMI: the administrator is responsible for ensuring that any such update falls within the license/contract terms [i.e., you've paid for the upgrade.]
:Details on the following would be great: :1. TFTP-ing code is simple. How would I point the a slave to use newly :uploaded code ?
Automatic as I recall.
