Two default routes and GRE tunnel does not work
May 04, 2006 5 Replies
Jump to replies (5)
If I have the 126.139.5.225 default routes the GRE tunnel will not work from one the computers on the LAN side. Can anyone help me.
service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! boot-start-marker boot-end-marker ! memory-size iomem 15 no network-clock-participate slot 1 no network-clock-participate wic 0 no aaa new-model ip subnet-zero ip cef ! ip audit po max-events 100 ! crypto isakmp policy 10 authentication pre-share group 2 lifetime 3600 crypto isakmp key xxxxx address xxxxxxxxxxxxxxxx crypto isakmp key xxxxx address xxxxxxxxxxxxxxxx crypto isakmp key xxxx address xxxxxxxxxxxxxxxx ! crypto ipsec transform-set des esp-des esp-md5-hmac ! crypto map xxxxxxxxx 10 ipsec-isakmp set peer xxxxxxxxxxxxxxx set peer xxxxxxxxxxxxxxx set peer xxxxxxxxxxxxxxxxx set transform-set des match address 150 ! interface Tunnel0 description to xxxxxxxxxx ip address 10.10.151.2 255.255.255.252 no ip route-cache cef no ip route-cache no ip mroute-cache tunnel source FastEthernet0/0 crypto map xxxxxxxx ! interface Tunnel1 description Tunnel to xxxxxxx bandwidth 10000 ip address 10.10.152.2 255.255.255.252 no ip route-cache cef no ip route-cache no ip mroute-cache tunnel source FastEthernet0/0 tunnel destination xxxxxxxxxxxxxxxxxxx crypto map xxxxxx ! interface Tunnel2 description GRE tunnel to xxxxx bandwidth 10000 ip address 10.10.153.2 255.255.255.252 no ip route-cache cef no ip route-cache no ip mroute-cache tunnel source FastEthernet0/0 tunnel destination xxxxxxxxxxxxxxxxxx crypto map xxxxxx ! interface Tunnel3 description To xxxxxxxxx ip address 10.199.0.34 255.255.255.252 no ip route-cache cef no ip route-cache no ip mroute-cache tunnel source FastEthernet0/0 tunnel destination xxxxxxxxxxxxxxxxxxxx crypto map xxxxxxx ! interface FastEthernet0/0 ip address 126.139.47.114 255.255.255.248 ip nat outside duplex auto speed auto crypto map xxxxxxx ! interface Serial0/0 bandwidth 1536 ip address 126.139.5.226 255.255.255.252 ip verify unicast source reachable-via rx 2000 no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip route-cache flow no ip mroute-cache down-when-looped no fair-queue service-module t1 timeslots 1-24 no cdp enable ! interface FastEthernet0/1 ip address 10.1.0.254 255.255.255.0 ip nat inside duplex auto speed auto ! ip nat inside source list 101 interface FastEthernet0/0 overload ip nat inside source list 102 interface Serial0/0 overload ip nat inside source static tcp 10.1.0.3 3389 126.139.47.114 3389 extendable ip nat inside source static tcp 10.1.0.20 1494 126.139.47.114 1494 extendable ip nat inside source static tcp 10.1.0.20 443 126.139.47.114 443 extendable ip nat inside source static tcp 10.1.0.3 3389 126.139.5.226 3389 extendable ip nat inside source static tcp 10.1.0.254 23 126.139.47.114 23 extendable ip nat inside source static tcp 10.1.0.254 23 126.139.5.226 23 extendable ip nat inside source static tcp 10.1.0.20 1494 126.139.5.226 1494 extendable no ip http server no ip http secure-server ip classless ip route 0.0.0.0 0.0.0.0 126.139.47.113 ip route 0.0.0.0 0.0.0.0 126.139.5.225 ip route 10.1.2.0 255.255.255.0 Tunnel1 ip route 10.10.100.0 255.255.255.0 Tunnel3 ip route 10.10.151.0 255.255.255.0 Tunnel0 ip route 10.10.152.0 255.255.255.0 Tunnel1 ip route 10.10.153.0 255.255.255.0 Tunnel2 ip route 10.100.1.0 255.255.255.0 Tunnel3 !
access-list 101 permit tcp any any access-list 101 permit ip any any access-list 102 permit ip any any access-list 150 permit gre host 126.139.47.114 host xxxxxxxxxxxxxxxxx access-list 150 permit gre host 126.139.47.114 host xxxxxxxxxxxxxxxxxxxxxxxx access-list 150 permit gre host 126.139.47.114 host xxxxxxxxxxxxxxxxxxx
You have two default routes for one, and try setting the default to the tunnel endpoint if you want to put the traffic in the tunnel - then crypted.
I believe that the vpn is probably failing on the other end. It has one destination for the vpn endpoint, but is getting responses from two different addresses. You should probably use PBR to send out the vpn traffic through just one interface (the one based on the address you use on the other side).
Actually, the setup that you have is enough to confuse a lot of applications, not just vpn. Even as much of a question... Why would you try to load balance this way with a T1 and an ethernet connection? Seems like that would serverly impact your network peformance. I would say to put a higher admin distance on the route going through the serial interface.
Jay How would I create default to the tunnel. If its 0.0.0.0 0.0.0.0 Tunnel1 wouldn't it send all traffic. Scooby the tunnel is fine if I remove the default route of 0.0.0.0
0.0.0.0 126.39.5.225 from the router. How would I give a higher admin distance for the serial.
I think to work with metrics... Just add 250 behind it for lower priority. Besides that: make sure to route the tunnel destination to a different interface/ip since it won't find the destination VIA the tunnel since the tunnel is not up because it can't find it's destination because etc.....
I tried adding 250 to the 126.39.5.225 to the default route.It works but when I am trying to telnet or access the 126.39.5.225 from the outside LAN it doesn't work.
Hans when you say "make sure to route the tunnel destination to a different interface", what should I do. I already have a route 10.1.2.0
255.255.255.0 Tunnel1.
