True routed interfaces for a 6500 switch?
Mar 09, 2006 8 Replies
ciscodagama
You seem to be requiring multilayer switching capability for the 6500 series switches. Take a look at should be able to route and configure QoS features withe the right supervisor engines. Cisco da Gama
True routed interfaces for a 6500 switch? open original image
A client has a number of ethernet connected sites operating at lines speeds of between 2 and 10mb/s. Does Cisco provide a blade for a 6509 chassis that provides true layer 3 routing? The physical ports would be
100mb or 1gb RJ45 copper. However they would be routed in software and allow for traffic rate shaping. Does such a beast exist?
You should be able to route and configure QoS features withe the right supervisor engines.
Cisco da Gama
You should be able to route and configure QoS features with the right supervisor engines.
Cisco da Gama
The 6500 has to run in IOS native mode in order to have routed interfaces.
AFAIK all ports on a native mode switch are routed ports by default.
Layer 2 switching on a port is enabled with the "switchport" command.
Ports are returned to being routed ports with the use of "no switchport" command.
Layer 3 isnt enough. I'm after layer 3 routed interfaces that can do BGP and traffic shaping. Standard 6500 10/100 interfaces only allow for traffic policing.
If the "lan" type interfaces don't have the features you want, take a look at the SIP modules. That's the "carrier" with various submodule type.
The 6500 supports BGP.
Most of the 6500 modules only support traffic policing.
A few WAN modules support traffic shaping.
I found a method that appears to do what i need. Sure enough the
10/100 blades in a 6500 are layer 2 devices that use a switch matrix. As such they dont support traffic shaping. However the MSFC does. If i assign a vlan to a given port and have the MSFC shape the vlan, then i effectively get what i am seeking. The port config would look something like:
interface FastEthernet4/1.1 description 2M link to site encapsulation dot1Q 9 ip address 1.1.1.1 255.255.255.252 traffic rate 2000000
I've only used modular QoS with policing on 6500 (shaping requires a FlexWAN card, I thought).
What kind of token bucket does the "traffic rate" use?
snipped-for-privacy@specialgreen.com
