tools like cached flow
May 12, 2009 2 Replies
hi,
any tools like the IOS "ip cache flow" ? it provides port ID, IP address and real-time traffic status ? I do not want to login the routers/layer3 devices...and press the keyboard (repeatedly ).
THX a lot in advance
Its called 'netflow', and you can find collectors which aggregate that data (you type a few commands into the IOS to export the netflow/cache- flow data to the collector). The tools (ManageEngine, Solarwinds, to name two) will then give you a web gui to view the data and splice it how you like. Of course almost all netflow tools are not free, but there may be a few out there (ntop was one, not sure if its still around) that are cost free.
ntop is still being actively developed and I have a customer using it who is very happy with what it does, namely provide a 'top'-like view of a network. If you want periodic reporting or long term analysis, look elsewhere.
