Telnet over Site to Site IPsec
Oct 27, 2007 8 Replies
Jump to replies (8)
I'm trying to troubleshoot a configuration that I inherited and I'm not sure where to start.
We have a retail client with three stores each with a PIX 501 connected via site to site IPsec tunnels to an ASA 5520 at a central location. Workstations at each store telnet to a Linux server at the central location.
For the past couple of weeks, the telnet connections at the store have been intermittently disconnecting. It seems to be happening maybe 3-4 times a day overall.
I don't see any errors on the firewalls logs or interfaces or on the network interface of the Linux server.
Any ideas on how I should troubleshoot this issue?
Thanks in advance! -- Vince
Do you have some configs we can see?
When the connection from linux disconnect does IPsec also disconnect from the peer.
How many workstations at each store ?
The PIX 501 by default only has 10 user license so it will not support more than 10 sessions
No, the IPsec doesn't disconnect. Other telnet sessions from the same location aren't dropped just one.
Two of the stores have PIXes with 50 user licenses. Those stores have between 5 and 10 workstations.
One store only has 2 workstations so they have a 10 user license.
It doesn't seem to be a user license issue, as the dropped user can immediately reconnect.
Assuming it is not an IPSEC issue, then I would put a sniffer ( PC with Etherreal) and capture the Telnet sessions to the Linux server.
When an incident occurs is it all of the workstations in a store that disconnect or just some?
Are all stores affected at the same time?.
Assuming it is not an IPSEC issue, then I would connect a sniffer ( PC with Etherreal) on the same LAN where the Linux server and capture the Telnet sessions to the Linux server. Look for TCP resets and the like.
Generally it's just a couple of workstations at a time, not all workstations at a store nor all stores.
The few workstations at a time - are they at one store or multiple stores - if they are at multiple stores then it may indicate that the issue is a the central site.
