static web key
Aug 07, 2005 2 Replies
I could config the wireless on my router 877 to work in open mode with no key, but when I tried the settings of static wep key, I could not connect at all. The config is as follows :
interface Dot11Radio0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow ! encryption vlan 2 key 1 size 128bit 0 aaaaaaaaaabbbbbbbbbbcccccc transmit-key encryption vlan 2 mode wep mandatory ! ssid mywep_d vlan 2 authentication open guest-mode ! speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 no cdp enable ! interface Dot11Radio0.2 encapsulation dot1Q 2 no cdp enable bridge-group 2 bridge-group 2 subscriber-loop-control bridge-group 2 spanning-disabled bridge-group 2 block-unknown-source no bridge-group 2 source-learning no bridge-group 2 unicast-flooding ! interface BVI2 ip address 192.168.2.1 255.255.255.0 ip nat inside ip virtual-reassembly !
I thought it was simple, but it is clearly that I miss something.
Thanks for your help,
DT
Hi Brandon, thanks for your note. Yes, my card supports 802.11g. I think I missed something or I was too tired :) : after making copy run sta , reload and reboot my notebook, all works fine. I think I had some wrong settings on my notebook.
It is on now, and I am going to try other cipher/authentication :)
Thanks.
DT
