Static Translations Disappearing
Oct 09, 2006 8 Replies
Jump to replies (8)
Static Translations Disappearing open original image
Hey there,
I bought a Cisco 837 ADSL router a couple of months ago, have configured it pretty well for my liking, and has been running fine mostly. One problem I'm having though is that static translations I've configured in the config are disappearing after, it seems, a period of time of them not being used. It's as if there's a translation timeout setting operating that removes unused static entries after a given period of time (I'm not sure about the length of time exactly but it seems to be around a few days).
The configuration commands I'm using to open ports are:
ip nat inside source static tcp 192.168.1.2 62020 interface Dialer0 62020 ip nat inside source static tcp 192.168.1.2 62019 interface Dialer0 62019 ip nat inside source static tcp 192.168.1.2 62018 interface Dialer0 62018 ip nat inside source static tcp 192.168.1.2 62017 interface Dialer0 62017 ip nat inside source static tcp 192.168.1.2 62016 interface Dialer0 62016 ip nat inside source static tcp 192.168.1.2 62015 interface Dialer0 62015 ip nat inside source static tcp 192.168.1.2 54211 interface Dialer0 54211 ip nat inside source static udp 192.168.1.2 54211 interface Dialer0 54211 ip nat inside source static tcp 192.168.1.2 18416 interface Dialer0 18416 ip nat inside source static tcp 192.168.1.2 7000 interface Dialer0 7000 ip nat inside source static udp 192.168.1.2 7000 interface Dialer0 7000 ip nat inside source static tcp 192.168.1.2 1919 interface Dialer0 1919 ip nat inside source static tcp 192.168.1.2 666 interface Dialer0 666 ip nat inside source static udp 192.168.1.2 666 interface Dialer0 666 ip nat inside source static tcp 192.168.1.2 220 interface Dialer0 220 ip nat inside source static udp 192.168.1.2 220 interface Dialer0 220
If I reload the router and issue the command 'show ip nat translations tcp | include ---' it shows all these defined ports as operating (open):
tcp 11.22.33.44:220 192.168.1.2:220 --- --- tcp 11.22.33.44:666 192.168.1.2:666 --- --- tcp 11.22.33.44:1919 192.168.1.2:1919 --- --- tcp 11.22.33.44:7000 192.168.1.2:7000 --- --- tcp 11.22.33.44:18416 192.168.1.2:18416 --- --- tcp 11.22.33.44:54211 192.168.1.2:54211 --- --- tcp 11.22.33.44:62015 192.168.1.2:62015 --- --- tcp 11.22.33.44:62016 192.168.1.2:62016 --- --- tcp 11.22.33.44:62017 192.168.1.2:62017 --- --- tcp 11.22.33.44:62018 192.168.1.2:62018 --- --- tcp 11.22.33.44:62019 192.168.1.2:62019 --- --- tcp 11.22.33.44:62020 192.168.1.2:62020 --- ---
...though after a while any of these that haven't seen use for 'a while' disappear, so I have to telnet in, conf t, and paste the config translation lines back in to get them back up.
I've been logging NAT translations out to syslog and this has captured these static entries being removed, though it hasn't helped me deduce why exactly:
%IPNAT-6-NAT_DELETED: Deleted tcp 192.168.1.2:62015 11.22.33.44:62015
0.0.0.0:0 0.0.0.0:0
I'm at a loss as to what's causing this so any help would be much appreciated.
Cheers.
-------------------------------------------------------------------------- An edited version of the startup-config below:
version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime localtime service timestamps log datetime localtime service password-encryption ! hostname c837 ! ! memory-size iomem 5 no logging buffered no logging console no logging monitor enable secret 5 $xxxxxxxxxx ! username xxxxx password 7 xxxxxxx clock timezone GMT 0 clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00 no aaa new-model ip subnet-zero ip tcp selective-ack ip tcp synwait-time 10 ip tcp path-mtu-discovery no ip domain lookup ! ! no ip bootp server ip cef ip multicast-routing ip audit notify log ip audit po max-events 100 ip ssh break-string no ftp-server write-enable ! ! ! no crypto isakmp enable ! ! ! ! interface Ethernet0 ip address 192.168.1.1 255.255.255.0 no ip redirects no ip unreachables ip nat inside ip pim sparse-dense-mode ip tcp adjust-mss 1452 ip igmp helper-address udl Dialer0 no cdp enable hold-queue 100 out ! interface ATM0 no ip address no ip redirects no ip unreachables atm pppatm link reset no atm ilmi-keepalive pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto ! interface Dialer0 ip address negotiated ip access-group 101 in ip access-group 102 out no ip redirects no ip unreachables ip mtu 1492 ip nat outside ip pim sparse-dense-mode encapsulation ppp ip igmp unidirectional-link dialer pool 1 dialer idle-timeout 0 dialer persistent dialer-group 1 ppp authentication chap callin ppp chap hostname xxxxxxxxxx@xxxxxxxxx ppp chap password 7 xxxxxxxxxxxxxxxxx ppp ipcp dns request ! ip nat log translations syslog ip nat translation tcp-timeout 900 ip nat translation max-entries 2048 ip nat inside source list 1 interface Dialer0 overload ip nat inside source static tcp 192.168.1.2 62020 interface Dialer0 62020 ip nat inside source static tcp 192.168.1.2 62019 interface Dialer0 62019 ip nat inside source static tcp 192.168.1.2 62018 interface Dialer0 62018 ip nat inside source static tcp 192.168.1.2 62017 interface Dialer0 62017 ip nat inside source static tcp 192.168.1.2 62016 interface Dialer0 62016 ip nat inside source static tcp 192.168.1.2 62015 interface Dialer0 62015 ip nat inside source static tcp 192.168.1.2 54211 interface Dialer0 54211 ip nat inside source static udp 192.168.1.2 54211 interface Dialer0 54211 ip nat inside source static tcp 192.168.1.2 18416 interface Dialer0 18416 ip nat inside source static tcp 192.168.1.2 7000 interface Dialer0 7000 ip nat inside source static udp 192.168.1.2 7000 interface Dialer0 7000 ip nat inside source static tcp 192.168.1.2 1919 interface Dialer0 1919 ip nat inside source static tcp 192.168.1.2 666 interface Dialer0 666 ip nat inside source static udp 192.168.1.2 666 interface Dialer0 666 ip nat inside source static tcp 192.168.1.2 220 interface Dialer0 220 ip nat inside source static udp 192.168.1.2 220 interface Dialer0 220 ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 no ip http server ip http access-class 2 no ip http secure-server ! ! ip access-list logging interval 1 ip access-list log-update threshold 1 logging trap debugging logging facility syslog logging 192.168.1.2 access-list 1 permit 192.168.1.0 0.0.0.255 access-list 2 permit 192.168.1.0 0.0.0.255 access-list 101 *** removed *** access-list 102 *** removed *** dialer-list 1 protocol ip permit snmp-server community public RO snmp-server enable traps tty no cdp run ! control-plane ! ! line con 0 no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 access-class 2 in exec-timeout 60 0 login local transport preferred all transport input telnet ssh transport output none ! scheduler max-task-time 5000 sntp server 193.62.22.66 ! end
My guess is that you are telling them to timeout.
Maybe a bug or maybe that's the way it is supposed to be?
router(config)#ip nat tra ?
tcp-timeout Specify timeout for NAT TCP flows timeout Specify timeout for dynamic NAT translations
Maybe since "timeout" is for "dynamic" translations tcp-timeout encompasses all translations.
I don't know -
is your friend.
I did look at information about 'tcp-timeout' on cisco.com before and it states that the command tcp-timeout "Specifies that the timeout value applies to the TCP port. Default is 86,400 seconds (24 hours)." which seemingly indicates the usual tcp-timeout limit for translations (dynamic I assume) is 24 hours. Surely if this value is running in the background by default then it should never affect static translations ?
I'll try replacing that 'tcp-timeout' for 'timeout' though as suggested.
Many thanks for the reply.
It does seem odd. I will try that out here. I don't use static translations but will configure one just for fun so there will be no harm in setting a timeout on it.
Could be a bug.
I have never changes the default timeouts on NAT but then I haven't used it in a big installation really.
It would be interesting to know if you see the same thing there. I'm running IOS c837-k9o3sy6-mz.123-4.t at the moment.
I made the change and reloaded though I think it could take at least a few days before I'll know if things are looking better. :-|
Thanks for the help.
Just to update; I replaced the 'tcp-timeout' command with 'timeout' though after some time I still logged a static translation being removed:
%IPNAT-6-NAT_DELETED: Deleted tcp 192.168.1.2:54211 11.22.33.44:54211
0.0.0.0:0 0.0.0.0:0
Puzzled about what could be causing this I'm looking into a theory now. Though the 54211 port was forwarded the service that utilises this port wasn't running on the system at 192.168.1.2 at the time the entry was deleted. I looked at the source ports the system was using for outbound TCP communications shortly after this deletion event and it looks like the operating system had probably recently used ports in the region of the 54211 port (it was using source ports around 55000 and climbing when I looked) when establishing outbound connections.
I'm wondering if it might be possible that if the 192.168.1.2 system uses an unused, but forwarded (in the router) port, that the router creates an outbound dynamic NAT entry, then after the '900' seconds timeout period clears that entry which also causes the static translation to be cleared (?). Seems ridiculous that it would do that if that turns out to be the case!
For now I've removed the 900 second 'timeout' line completely to see if static translations will still get timed-out. I'll try to check what ports the 192.168.1.2 system uses close to a translation timeout too if I'm around to catch it to see if it looks related.
Still, any insight into this problem would be much appreciated if anyone has any ideas.
Cheers.
Well I'm at a loss. Here's how it goes;
A:1234 ---> c837 ---> Internet
The c837 router runs dynamic NAT for the local area network machines ('A' and others) to translate packets to and from the Internet. Simple enough.
Machine 'A' hosts services (on port 1234 for example) that are only active periodically. The c837 router has these service ports defined as static NAT 'forwarding' rules (see startup-config above). Access to the services works fine so long as the service is actively running on machine 'A'. If the 'port 1234' service is not running on machine 'A', the operating system will, when the need arises, utilise port '1234' for creation of outbound connections to the Internet, eg: A:1234 ---> c837 ---> google.com:80.
When it does this the Cisco 837 router creates a dynamic NAT entry like;
Created tcp A:1234 C837_WAN_IP:1234 google.com:80 google.com:80
Given the dynamic nature of that NAT entry it times out after a period of non-use (or FIN/RST is seen). When it does time out the dynamic entry is cleared, BUT, it also clears the router's static '1234' forwarding rule, e.g.;
Deleted tcp A:1234 C837_WAN_IP:1234 0.0.0.0:0 0.0.0.0:0
Instead of spending 180 hours trying to troubleshoot what you know should be working I would download three or four different versions of IOS for this router and see if they have the same behavior. It sounds to me like you are running into a NAT bug. I have found over the years of working with cisco (and working on TAC for 5 years) that if its configured correctly, but it doesn't work, its usually a ..ere undocumented feature or caveat as Cisco likes to call them. It wouldn't hurt to change IOS and see if you have the same behavior. I would try to change trains as well as versions, no telling if the bug is even fixed. Also you could check your version of IOS against the bug find tool, just do a cco search. Based on the testing you have done it kind of smells like a rat ..ere a bug.
-------- Original Message --------
Hey thanks for the reply.
Indeed I've spent a while trying to figure out the problem and can only assume so far that it's either a bug, or that I'm not knowledgable enough to know where I'm going wrong with the configuration (I'm new to IOS).
I have been thinking about trying other IOS versions, though, I could do with installing another 16MB of DRAM as the 12.3.(4)T IOS I'm running at present happily consumes most of the available DRAM (32MB) when the router gets busy (when the number of dynamic NAT translations hit the roof (2500+)). I do have some alternative IOS versions already though pretty much anything larger than 12.3.(4)T when decompressed won't fit in RAM without running into trouble. I could come down on versions (probably more sensible) though have been a bit reluctant to do so; a fault of my own really as I tend to believe higher versions should be the most evolved, stable, secure, etc software to use.
I looked into some alternative configuration methods to 'forward' the ports after posting here and, though not really understanding too much of what I was doing, did manage to find a workable solution, though to me it seems to be a bit of an awkward workaround. If I used the following to open a port;
...then the problem would occur. If I do a 'show ip nat statistics' I get something akin to the following output;
Total active translations: 66 (0 static, 66 dynamic; ?? extended)
...where it just shows all translations being dynamic (0 static, not sure about the 'extended', I can't remember).
However, after playing around with things I found the following to work correctly;
ip nat inside source static tcp 192.168.1.2 220 123.123.123.123 220
...with "123.123.123.123" being my outside static IP address. If I do a 'show ip nat statistics' now I get something like the following;
Total active translations: 66 (16 static, 50 dynamic; 66 extended)
...where it now shows the static translations as actually being static. I think this is a bit daft really as the only reason I can do this is because I've a static IP address with the ISP. If I had a dynamic address then I don't see how folks could work around this problem so easily without frequent reconfiguration of the external address as and when it changes. :-s
I will try to get some more DRAM in the router sometime and run through some alternative IOS versions as you say.
Thanks again.
