Where could I find a list of OIDs used on a Cisco 3750? Is it possible to to retrieve, via SNMP, info such as ARP tables and the switches own IP tables(from show ip arp). Additionally, stuff like retreiving CDP neighbor information and router configurations(without having to use a tftp server) would help immensely.
-- conrad
HII've been tasked to get all our hardware reporting to MicrosoftOperations...
B
bod43
Yes.
Probably.
Doubtful. Yes with snmp *and* tftp server.
I am not 100% sure about 3750 but I would be surprised it most of above was not correct.
The ARP bit is in an RFC mib and not necessarily in a Private MIB so will be supported on all platforms.
CDP will obviously be in a Private MIB
Router config is something like Set tftp target address mib Set this, set that Set magic "trigger" mib that initiates transfer
all one line -
Merge 4 lines into one URL.
A google search of this group for [snmpset config tftp] returns a few promising looking hits. Note, the old catalysts, 500x, 400x could well be different. stick to advice about routers or modern IOS Switches.
all one line -
Easiest way to find out what is suported is to do an snmpwalk of the whole device.
There are some free tools available.
for windows:-
getif.exe
There is also a command line snmpget ...walk, ....set. UCD - University C Davis (Davies?) or womething like that.
CISCO-CDP-MIB
I dont have the tools here right now, or a 3750 to play with so I will stop here.
Search of
for [ARP MIB]
How to Clear a Single ARP Entry in a Router Using SNMP "based on all devices which support RFC1213MIB" Your 3750 does.
This may point you in the right direction.
Post back if you are still stuck.
Report Content
ASAP.
