SCP output from CiscoWorks
Aug 23, 2007 1 Replies
Getting the following output from CW config archive job:
CM0151 PRIMARY STARTUP Config fetch failed for DUCE-gw Cause: Failed to fetch config using SCP.Privilege denied. Verify SCP is enabled or not. Could not detect protocols running on the device PRIMARY-STARTUP config Fetch Operation failed for TFTP. Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.CM0151 PRIMARY RUNNING Config fetch failed for DUCE-gw Cause: Failed to fetch config using SCP.Privilege denied. Verify SCP is enabled or not. Could not detect protocols running on the device PRIMARY-RUNNING config Fetch Operation failed for TFTP. Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.
The error is that "privilege is denied", yet I have given all users level 15 privilege. SCP is enabled. Any ideas?
This turned out to be an AAA issue; the command:
aaa authorization exec default group tacacs+ local
is required for scp to operate properly in an AAA environment.
