tough and challenge questions from a cisco exam.need help. thankyou very much
Apr 01, 2006 13 Replies
Jump to replies (13)
1=2E Scenario: You have to connect Dell PowerEdge 2850 server to Cisco Catalyst 2950-24 switch. =B7 Question: What would your port(s) configuration be to ensure maximum network throughput ?
2=2E Scenario: You have 2 Cisco catalyst 4509 switches in your branch, connected to each other using Gig port on Sup Module. VLAN 1 is you primary VLAN for users. See below for the configuration of the VLAN on both switches.
4509-1 config: interface Vlan1 ip address 10.2.100.1 255.255.0.0 no ip redirects standby 1 ip 10.2.100.2 standby 1 priority 105 standby 1 preempt
4509-2 config: interface Vlan1 ip address 10.2.100.3 255.255.0.0 no ip redirects standby 1 ip 10.2.100.2 standby 1 priority 100
=B7 Question: Which switch should be the root device for Spanning tree ? Answer: Based on the HSRP configuration, 4509-1 will be the root device for spanning tree.
3=2E Scenario: 2 branch offices connected through managed private LAN, routers R1 and R4 belongs to you, routers R2 and R3 are managed routers and you have no control over it. You want to run OSPF as a routing protocol across those 2 branches.
=B7 Question: How you can achieve this.
4=2E Scenario: Small branch office has Cisco Catalyst 2950G-24 switch and Cisco 1841 router with 2 Fast Ethernet interfaces. Fa0/0 connected to Private line pointed to headoffice, Fa0/1 connected to switch. Internal network in the office - 10.0.0.0/24. You have to create separate network in this office for test equipment (i.e 10.0.1.0/24), devices on this network should be able to connect to your headoffice network and to old branch network (10.0.0.0/24).
=B7 Question: How you can do this ?
5=2E Scenario: Small branch office has own Internet connection terminated on Cisco PIX 501, (see configuration below). Your office has a site to site VPN connection to the headoffice.
interface ethernet0 10baset interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password encrypted passwd encrypted hostname ScarPix domain-name dscltd.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol ils 389 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 10.7.0.0 TCA-Main name 10.0.0.0 Lang access-list in_out_nat0_acl permit ip 192.168.255.0 255.255.255.240 Lang 255.255.0.0 access-list in_out_nat0_acl permit ip 192.168.255.0 255.255.255.240 TCA-Main 255.255.0.0 access-list out_crypto_20 permit ip 192.168.255.0 255.255.255.240 Lang
255.255.0.0 access-list out_crypto_20 permit ip 192.168.255.0 255.255.255.240 TCA-Main 255.255.0.0 pager lines 24 logging on mtu outside 1500 mtu inside 1500 ip address outside pppoe setroute ip address inside 192.168.255.2 255.255.255.240 ip audit info action alarm ip audit attack action alarm pdm history enable arp timeout 14400 nat (inside) 0 access-list in_out_nat0_acl timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local aaa authentication telnet console LOCAL aaa authentication ssh console LOCAL http server enable http 10.0.250.170 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac crypto map out_map 20 ipsec-isakmp crypto map out_map 20 match address out_crypto_20 crypto map out_map 20 set peer 209.135.126.147 crypto map out_map 20 set transform-set ESP-3DES-SHA crypto map out_map interface outside isakmp enable outside isakmp key ******** address 209.135.126.147 netmask 255.255.255.255 no-xauth no-config-mode isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash sha isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 telnet timeout 5 ssh 209.202.119.2 255.255.255.255 outside ssh timeout 5 console timeout 0 vpdn group Bell request dialout pppoe vpdn group Bell localname vpdn username password ********* dhcpd address 192.168.255.8-192.168.255.14 inside dhcpd wins 10.0.0.3 dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd domain dscltd.com dhcpd auto_config outside username password encrypted privilege 15 terminal width 80 Cryptochecksum:e62b274f3c900e2a451d81748f320df0 : end
=B7 Question: Can they use own internet connection for internet access and if not, what you would change in config to allow this. PIX Version 6.3(3)
6=2E Scenario: Small office has Internet Connection terminated on Cisco PIX firewall all local computers connected to Cisco Catalyst 2950 switch. You need to create additional subnet on internal branch network, this new subnet must have Internet access and ability to talk to existing internal subnet. =B7 Question: How you can achive this if: a) You have Cisco PIX 501 b) You have Cisco PIX 506 c) You have Cisco PIX 515 with 2 Ethernet interfaces d) You have Cisco PIX 515 with 3 Ethernet interfaces
Translations.
We cannot answer b) or c) without knowing the software release. We can, though, answer for a) and d) without knowing the software rev.
THANK YOU FOR YOUR REPLY.Can you tell me how to answer a) and b)?
That depends. Can you quote enough context in your replies so that we can figure out what "a)" and "b)" refer to?
I do not use googlegroups as my main newsgroup reading or posting interface, so the previous context is -not- "right there" to look at. Postings expire, postings do into timewarps, postings don't arrive. You need to quote enough for people to know what you are talking about.
(And no, I am not likely to switch to googlegroups as a usenet interface. I read far far too many messages per day to put up with googlegroup's slim features.)
I checked the cisco wesite and thought I can set 802.1q trunk on pix.For example, if the pix has only 2 ports, then one for internet and one for the 2 private vlan. I must set a physical interface for one vlan and logical interface for another vlan.These 2 interface are configured on the real one interface.But if the pix has 3 ports.I am not sure if i can set one physical int to E1,another one physical int to E2,E3 to internet.There is on logical interface now.There should 2 calble connect between the 2950 and pix.For this case is it right?
Yes, that is the key for solving the question that you (again) failed to quote.
Multiple cables to the 2950 is an acceptable solution, as we know the 2950 has multiple ports.
The next step to answering the question in full is to identify the circumstances under which 802.1Q is supported on the various PIX models.
Hi, my friend,I still do not know hot to solve the question 5. It seemed all the traffic go through the vpn channel,that is why the branch can not use internet.But I am not sure where is the problem and how to fix it.Thank you first for yor help
Please learn how to quote in google groups.
My previous answer with respect to Question 5 of your original posting was "Translations". What is a translation on the PIX, how does one configure a translation on the PIX, and what are the consequences of having failed to configure a translation?
thank you ,my friend.Sorry for i am a newcomer to google group and english is not my first language.This time i changed it to nat(inside)
1 0 0 and global (outside) 1 pppoe setroute.For globale command i am not sure if it works for there is no exact ip address for this case
Hi, my friend. I think I just add nat (inside) 1 0 0 global (outside) 1 interface.Then it should be ok
global (outside) 1 pppoe setroute will not work, but your later suggestion of
global (outside) interface
should work.
Walter Roberson =E5=86=99=E9=81=93=EF=BC=9A
Thank you for your kindly help!
