Routing Issues
Mar 26, 2007 1 Replies
We've got a site to site leased line between a 10.44.5.xx network and
10.44.1.xxx network we've now added another 10.4.0.0 network which is run through a seperate router on the the 10.44.1.xx network
so 10.44.5.251 (cisco 1841) leased line
10.44.1.251 (cisco 1841)
10.44.1.250 (cisco 2600 series) leased line
10.4.0.0 network
Configs for both the 10.44.5.251 and 10.44.1.251 router are shown below, EIGRP has been set on both but i believe this can be removed (however we have tried this but found the connection dropped)
Any advice would be appreciated:
version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname MK ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings enable password 7 153B530D143A27213B6721 ! no aaa new-model ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ip domain name yourdomain.com ip address-pool local ! crypto pki trustpoint TP-self-signed-4049385774 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-4049385774 revocation-check none rsakeypair TP-self-signed-4049385774 ! crypto pki certificate chain TP-self-signed-4049385774 certificate self-signed 01 nvram:IOS-Self-Sig#3401.cer username cisco privilege 15 secret 5 $1$fj0/$dgMDX3q4AIWBlqQWxSn5b1 ! interface FastEthernet0/0 ip address 10.44.1.251 255.255.255.0 duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/0/0 bandwidth 1024000 ip address 10.44.10.5 255.255.255.252 ! router eigrp 100 network 0.0.0.0 auto-summary ! ip classless ip route 10.0.0.0 255.0.0.0 10.44.1.250 ip route 10.44.5.0 255.255.255.0 10.44.10.6 ip route 192.168.0.0 255.255.255.0 10.44.1.14 ! ip http server ip http access-class 23 ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! access-list 23 permit 10.44.0.0 0.0.255.255 access-list 101 permit ip any any control-plane ! line con 0 login line aux 0 line vty 0 4 access-class 23 in privilege level 15 login transport input telnet ssh line vty 5 15 access-class 23 in privilege level 15 login local transport input telnet ssh ! end
Second Config
! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Elland ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings enable password 7 153B530D143A27213B6721 ! no aaa new-model ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ip domain name yourdomain.com ip address-pool local ! crypto pki trustpoint TP-self-signed-4049385774 enrollment selfsigned revocation-check none rsakeypair TP-self-signed-4049385774 ! interface FastEthernet0/0 ip address 10.44.5.251 255.255.255.0 duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/0/0 bandwidth 1024000 ip address 10.44.10.6 255.255.255.252 ! router eigrp 100 network 0.0.0.0 auto-summary ! ip classless ip route 0.0.0.0 255.255.255.255 10.44.10.5 ! ! ip http server ip http access-class 23 ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! access-list 101 permit ip any any ! control-plane ! line con 0 login local line aux 0 line vty 0 4 access-class 23 in privilege level 15 login local transport input telnet ssh line vty 5 15 access-class 23 in privilege level 15 login local transport input telnet ssh ! end
I have not looked too closely, but my initial reaction is it looks like you are wasting CPU cycles running EIGRP. Your statement that "you need EIGRP enabled to keep the connection up" is ambiguous. Do you mean the carrier drops the link or that the link stays up but traffic ceases to flow? The only thing EIGRP appears to be doing in this config is exchanging hello packets so there is always traffic on the link when EIGRP is running, and possibly complete silence when it is not.
Good luck and good hunting!
