Routing between 2 firewalls
May 12, 2006 3 Replies
Jump to replies (3)
Routing between 2 firewalls open original image
I have 2 networks with their own fw, routers and internet connection. I want to joing them using a DMZ zone on each firewall connected via a switch. As per this diagram:
[IMG]
The problem is that I can't attach to any of the servers in the other network. The Office PC's need to be able to attach to the Admin servers etc in the other network.
The PIX FW are Pix 515 7.0 they have 4 x extra ports in each of them.
I need to know exactly how to do this as I don't know that much about PIX firewalls.
thks
On each Pix, within Configuration/Building Blocks/Hosts/Networks, select the interface facing the dmz switch and define the opposite sides network. Then click 'next' and define a static route using each pix as the gateway. That tells the Pix's of each sides network and how to get there. You then just need to add the appropriate traffic rules.
BernieM
How would you do that just using the command line ?
In relation to the jpeg, assuming 24-bit masks, here's the routing rules ...
Pix on the left:
name 192.168.1.0 Linux-Apps name 192.168.3.0 Linux-Web
route dmz2 Linux-Apps 255.255.255.0 172.16.32.5 1 route dmz2 Linux-Web 255.255.255.0 172.16.32.5 1
Pix on the right:
name 192.168.0.0 Backup-Srv name 10.10.10.0 Test-Srv
route dmz5 Backup-Srv 255.255.255.0 172.16.32.1 1 route dmz5 Test-Srv 255.255.255.0 172.16.32.1 1
Do you know what access rules are needed?
BernieM
