routers and certificates
May 30, 2006 1 Replies
Hello, I configured a IPSec tunnel between 2 routers using RSA authentication. I would like to use certificates but looking at the documentation it is needed to go thru an enrollment mechanism specifying a URL for the ca server. I created certificates with my own CA using OpenSSL. how can I import a certificate inside the router (cert + private key) ? thansk a lot
Rick
if over a private/frame/mpls/etc netowrk should use pre shared keys, much less overhead. Only need certs if Internet/VPN connectivity
