RIPv2 between Cisco 851 and 871
Mar 09, 2009 3 Replies
Jump to replies (3)
I have a small lab topology that can be viewed here:
Here is what I am trying to do:
1) Get RIP v2 working between routers R1 and R2.
2) Have the routes of 192.168.1.1 and 192.168.4.1 advertised to R2.
The problem I having is that R1 has no problems receiving info from R2 but R2 has problems receiving any updates from R1.
I want to save space in this post so I haven't posted the config. Here is some debug output though:
R1 (Cisco 851)
1124912: .Mar 8 16:02:58.129 PCTime: RIP: sending v2 update to 224.0.0.9 via Vlan1 (192.168.1.1)
1124913: .Mar 8 16:02:58.129 PCTime: RIP: build update entries - suppressing null update
1124914: .Mar 8 16:02:58.129 PCTime: RIP: sending v2 update to 224.0.0.9 via Vlan1 (192.168.2.1)
1124915: .Mar 8 16:02:58.129 PCTime: RIP: build update entries - suppressing null update
1124916: .Mar 8 16:02:58.129 PCTime: RIP: sending v2 update to 224.0.0.9 via Vlan1 (192.168.4.1)
1124917: .Mar 8 16:02:58.129 PCTime: RIP: build update entries - suppressing null update
1124945: .Mar 8 16:04:39.842 PCTime: RIP: received v2 update from 192.168.2.2 on Vlan1
1124946: .Mar 8 16:04:39.846 PCTime: 192.168.3.0/24 via 0.0.0.0 in 1 hops
1124947: .Mar 8 16:04:39.846 PCTime: RIP: Update contains 1 routes
R2 (Cisco 871)
*Mar 2 10:50:18.747: RIP: sending v2 update to 224.0.0.9 via FastEthernet4 (192.168.2.2)
Mar 2 10:50:18.747: RIP: build update entries
*Mar 2 10:50:18.747: 192.168.3.0/24 via 0.0.0.0, metric 1, tag 0
*Mar 2 10:50:18.747: RIP: Update contains 1 routes
Mar 2 10:50:18.747: RIP: Update queued
*Mar 2 10:50:18.747: RIP: Update sent via FastEthernet4
Mar 2 10:50:18.747: RIP: ignored v2 packet from 192.168.2.2 (sourced from one of our addresses)
I have occasionally seen an error message: RIP: ignored the request received from unlisted network.
My understanding is that all routes should be advertised between the 2 interfaces and everything should just work.
The main questions I have is:
1) Why isn't R2 receiving updates? Is there something with the 851/71 that needs to be configured differently?
--Paul
essing null update
essing null update
essing null update
168.2.2 on Vlan1
.0.0 in 1 hops
net4 (192.168.2.2)
I have not read and studied fully all of the detail and maybe I missed something, however:-
From your diagram, the first thought is that
192.168.2.1 may be a secondary address on R1. Dynamic routing protocols do not work with secondary addresses is the model that I use.
Perhaps the source address fro the RIP from R1 is
192.168.1.1 and R2 (192.168.2.2) is ignoring the updates.
I doubt that many people read this group on 9600bps modems now so I would not worry about posting a couple of configs:)
Yes, it is a secondary address but I've not known this to be a problem with RIP. Perhaps someone else can confirm this?
Vlan1 (192.168.1.1)
null update
Vlan1 (192.168.2.1)
null update
Vlan1 (192.168.4.1)
null update
(192.168.2.2)
You might find -
interesting. You should verify that later IOS behaviour has not changed.
I have mostly used OSPF and it ignores secondary addresses. I wonder if "redistribute connected" includes them? I was surprised to note recently (studying obsolete rubbish for cisco exams) that not all routing protocols had similar behaviour. Sadly remembering obsolete rubbish for long enough to pass is proving to be quite tough:(
Secondary addresses are in any case a horrible knudge.
