Remove "switchport mode dynamic desirable"
Nov 03, 2005 2 Replies
Hi all,
I have just deleted the config from a Catalyst 3550-24 to restore it to factory settings.
From some reason all ports, both FastEthernet and GigabitEthernet have
"switchport mode dynamic desirable" enabled by default.
I am used to seeing unconfigured switches with running configs similar to:
! interface FastEthernet0/1 ! interface FastEthernet0/2 ! interface FastEthernet0/3
And not:
! interface FastEthernet0/1 switchport mode dynamic desirable ! interface FastEthernet0/2 switchport mode dynamic desirable ! interface FastEthernet0/3 switchport mode dynamic desirable
Any suggestions how I can remove this option? "no switchport mode dynamic desirable" does not seem to work.
Thanks,
Paul
I haven't got a 3550 here to try but one of the other switchport mode options will be the default and when set to the default option then the command is not shown in the config.
Regards,
Nick Ersdown
Hi..
'switchport mode dynamic desirable' is to enable the port dynamically for trunking for current or future use.
for any particular port on this switch, if you are connecting it to a
  1. workstation / server : use these comands config -if#switchport mode access config -if#spanning-tree portfast
  1. To connect to other switches (for STP participation) config -if#switchport mode access
  2. If you want use the port as trunk
leave that command on..
optionally for servers, you may also want to use spanning-tree bpdu guard HTH Gibs
snipped-for-privacy@aol.com wrote:
