Remote Dialup Access to network - Simple Solution?
Nov 11, 2005 2 Replies
Aaron Leonard
If you're looking for a low-end router that has both an integrated analog modem and switched 10/100Mbps LAN ports, the 1811 would be it. If you were willing to use an external modem, then you could use an 851 or 871. I believe that our routers would support all the features…
I'm looking for a Cisco product that is similar to this one:
[...snip...] Remote Access EtherNet Modems
Remotely Support Devices on Ethernet. The Dial-In Ethernet Modem (9300-RADES) combines a four port managed switch with a 56K modem, allowing a remote connection to your Ethernet network. The built-in management interface allows flexibility when implementing the device to your new or existing application. [...snip...]
Do they make such a thing?
Thanks, Scott
the closest thing cisco does to a network modem, is AS5x00, I think.
I believe that our routers would support all the features described on the page below but for analog caller ID.
Cheers,
Aaron
