Remote Access or Branch Office Solution Needed
Jun 27, 2006 6 Replies
Jump to replies (6)
We are looking for the best recommendation for the following situation for sharing files on our server across a WAN. In Building A (call it BA), our server is Windows 2003 Standard Edition and it has (1) network
card with (3) XP client computers and is a DC. We access the Internet via a cable connection. We do not currently have a Static IP address from our ISP. We have text documents & a database file for a program we
use on the clients located on this server. We want to access these documents and database file from Building B (call it BB) which is (2-3)
blocks away from BA and has (3) XP workstations, without a server, currently sharing a cable Internet connection The workstations in BB run the same programs (software is installed locally) as those in BA, but need access to the database file and documents in BA.
We are familiar with setting up VPNs using SBS2000 and remotely accessing workstations on a network using RDC. However, there may be occasion where users in BA will be using their computers and we would not want to permit a RDC to those PCs just in order run the approriate software or open shared documents.
What hardware,setup would be required in BA and BB to configure this remote/WAN access? What are the latest,greatest technology options to accomplish this?
We are assuming a Static IP in BA, adding another NIC (to isolate internal network from external) and new router with VPN support are necessary?
Question: Would it be necessary for both sites to have a Static IP? Any recommendations on reading about Branch office setups?
Thank you!
You may wish to investigate the Cisco Small Business Network Designer:
http://64.224.10.185/sbnd/child/1.0/index.asp Hope this helps.
Brad Reese BradReese.Com - Cisco Network Engineer Directory
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
Sounds like something a couple of Cisco Linksys VPN routers could handle
Cisco does have a Branch Office Solution web page:
Sincerely,
Brad Reese Cisco Repair
Thanks for the reply. Does this mean that workers at the "branch office" would be added to the domain, and login as if they were in the same building? Meaning they would not use Remote Desktop? Does a VPN require Static IP from ISP for both locations or just one?
Would you recommend a second NIC on the server?
Thanks!
Merv wrote:
It would be helpful to directly call Cisco Pre-Sales Support
1-800-745-7381 in the USA or Canada between 8:00 A.M. and 8:00 P.M. EST
Additionally, you may reach Cisco Pre-Sales Support at 800-553-6387, option 2, between 8:00 a.m. and 8:00 p.m. Eastern Time.
Cisco Pre-Sales Support Email:
International Cisco Pre-Sales Support Phone and Email:
Sincerely,
Brad Reese Cisco Technical Forums
Thank you for the reply..however just looking for a simple answer from someone on what "interface" we would be using to connect to the main building--that is, what would it be like...would it be just like you were on a "regular" network and would not have to use RDC?
wrote:
