rate-limit parameters
Dec 01, 2006 1 Replies
rate-limit parameters open original image
I want to learn more about command rate-limit.Concretely, I want to know more detail about parameters normal burst bytes and maximum burst bytes and the best adjustment for those parameters.
A CCO search for [rate-limit bucket token]
Turns up:-
This article discusses the more modern Modular QoS commands but the principles are the same and there should be enough here to get you searching productively.
the rate-limit command does "policing".
