rapid-pvst
Jul 12, 2005 5 Replies
Jump to replies (5)
Can anyone tell me why my cisco 3750 switch running rapid-pvst does a fast convergence, when I plug in a server? The covergence affects all devices on the switch to lose connection.
I thought that only the port that gets a connection should go to the spanning tree convergence..not all of the ports?
Any help would be great..
Ok but do I also have to configure BPDU guard and Filter?
W artykule snipped-for-privacy@vedior.nl napisa³(a):
Put spanning-tree portfast on all interfaces you want to exclude from spanning-tree topology.
TP
I experienced this once with a 3750 (as well as the replacement that Cisco sent). Turned out to be a software problem. Software image was c3750-i5-mz.121-19.EA1c.bin Cisco never acknowledged an issue with the release even though I reported it to them.
I'll be interested to hear what release you are using and if upgrading fixes it.
Jim
bpdufilter statment filters out all bpdu messages on interface. It should be only enabled on ports connected to single machine.
TP
Thanks indeed we have -> c3750-i5-mz.121-19.EA1c.bin
I think that's the problem.
